Is it possible to add labels to projected objects AFTER they are projected?
I know how to do it while I'm projecting them but can't figure out how to do it after?
Mark
Mark, if you pick the projected object on the screen, look at the far left of the ribbon. There is a command to Add Object Label. It uses the default that is set in Feature Settings for Section Views.
Optionally, you can pick the object and then right click to find the option on the shortcut menu.
Tim
