I need to add simple bearing and distance labels to some lines in a drawing. But when I select "add labels" from the annotate tab, then "add line and curve labels" the command bar displays _AeccAddFeatureLineLabels but nothing happens.
I created this document on another computer using AutoCAD 2011 (not civil 3d). The strange thing is that ADDFEATURELINELABELS works fine in another drawing I have which was sent to me by a surveyor.
What could be the difference?
I'm having simlar problems.
Add labels
Line
Bearing and Distance
Select entiry
Entity must be line, polyline, etc.
Entity IS a POLYline.
Why won't it label?
Did you ever get a solution for this?
I've tried labeling feature lines projected to profiles, pipes in profiles, and alignment fixed point with the labeling feature refusing to work.
Just sent 2 people to a 3d class and asked them to ask the instructor. Instructor said he had never heard of such a thing.
XP Pro 2011.
