I'm wanting to have the invert elevations of a structure be part of the structure properties in a pipe network. Right now, the inverts only seem to be listed under the pipes' properties. My end goal is to export the network to a SDF and then SHP file for use in a municipality's GIS and I need the invert info to be a portion of the structure and not only the pipes so that it shows up when a strucure is queried in the GIS.
Thanks!
C3D 2014 SP2
Windows 7 Pro
HP ProBook 4530s
You're gonna need a custom solution for this.
When go to structure properties the connected pipe tab has the inverts. That can't be queried?
