I am trying to add an entry point to a retention pond that was created by grading tools. I will to entry point to be shaped like a trapezoid. I also want to grade a entry point to the slope of pond to control water erosion.
Please help me. I have been trying to add the entry point for days.
I have tried to create breaklines in the surface but there are problems with the elevations of the breakline. I tried using the grading tools but it didn't blend into the existing surface.
Mark Green
Working on Civil 3D in Canada
Use feature lines with the desired elevations assigned to them, then add those as breaklines to the retention pond surface.
is the a site issue with the FL's?
Your Name
Your Name
I have found it easy in the past to build my ramp in another dwg, dref the resultant surface to the pond, and paste them together. This avoids your FL's fighting with each other.
Click on the feature line, right-click, select Elevation editor. You can add elevation points from the panorama, or use the contextual ribbon.
No there is no site issue. I add a create a feature line then add the breakline into the pond surface. The pond was created using the grading tools.
Mark Green
