I created a corridor utilizing a profile, assembly and alignment. Worked well. I then created a surface from that corridor. The surface type should be displaying contours, but I do not see any. What am I doing wrong? The corridor display shows it covering the area that it should cover.
I did this once before and I had trouble with it that time as well. I remember the fix had something to do with adding code data from the corridor to the surface. I used a "+" button, but now have no idea where I did this at.
Any help will be appreciated.
I found it - I had the great idea while typing the question. It is not under surface properties, it is under the surface tab of the corridor properties box.
