Civil 3D Forum
Add Block or symbol to alignment label?
10 REPLIES 10
Message 1 of 11
rhdins
2820 Views, 10 Replies
This is what I'm trying to achieve, except with a Civil3D label.
I want to add the circle with the typical detail callout to an alignment label.  I can format the text just fine, but can't figure out any way to add a symbol to a label.  For example, I was thinking I would create a "water meter" style with the correct number for water meters, so there would be a block or something attached to the label.
Any suggestions on how to do this?
10 REPLIES 10
Message 2 of 11
dgordon
in reply to: rhdins
I made this one with two text components and a line component.  It doesn't appear as though a block is necessary.
I did notice however the block component is also available for this type of label.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 3 of 11
IanMcClain
in reply to: rhdins
I believe you can add blocks to a style in the Label Style composer. See attached.
Ian McClain
Message 4 of 11
Joe-Bouza
in reply to: IanMcClain
I concur with your route, Ian
Your Name
Your Name
Message 5 of 11
rhdins
in reply to: dgordon
Thanks, I've been able to match that, except the circle.  How did you add the circle in your label?
Message 6 of 11
rhdins
I also tried adding a block.  It worked, but I had some problems getting it to rotate to my viewport.  It seems like using a text object gives me a little more control.
Message 7 of 11
Joe-Bouza
in reply to: rhdins
Make a block of the circle and stick with the insert point where the leader will attach. In the lable composer add a block, select the one you made adjust your fields to where they belong
Your Name
Your Name
Message 8 of 11
dgordon
in reply to: rhdins
the circle is one of the border shapes you can put around a text component.   just set border to true and select circle instead of rectangle.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 9 of 11
rhdins
Thanks, I didn't notice that you could change the border shape.  That works perfectly.  This is the final result.
Message 10 of 11
mlreid23
in reply to: rhdins
How did you get your labels to rotate from left to right of the circle symbol? Is that an automatic setting?
Message 11 of 11
Cadguru42
in reply to: mlreid23
I'd like to know also. I've been manually moving the leader to snap to the edge of the circle or line every time.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Rail Community
