Valued Contributor
johnwilson0805
Message 1 of 5 (365 Views)
ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
365 Views, 4 Replies
10-29-2012 12:29 PM
I need to add a turnout (not intersection) along a bike path at a given station (see pdf attachment)
if I draw a turnout with nice arcs and lines, is there a way to add it to the corridor with extended
cross slope from the assembly at that point?
John Wilson
yes, it's possible.
You have to use a BasicLaneTransition.
Please use help for better explainance.
Good luck.
Thank you very much. It helped to research edit target to a polyline layout
John
While polylines can be used as targets they are static entities, so they don't move if your alignment changes. A better solution is to use offset alignments with widenings. Then you can move the widening along the baseline or edit it parametrically. You want a solution that is dynamic to changes to the design.
Also for a widening you should consider using an offset in your assembly so that your template will be perpendicular to the edge of pavement through the widening.
Valued Contributor
bpoleuca
Message 2 of 5 (362 Views)
Re: ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
10-29-2012 12:55 PM in reply to: johnwilson0805
yes, it's possible.
Good luck.
Valued Contributor
johnwilson0805
Message 3 of 5 (337 Views)
10-29-2012 04:48 PM in reply to: bpoleuca
John
Neilw
Message 4 of 5 (325 Views)
10-29-2012 11:45 PM in reply to: johnwilson0805
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Contributor
johnwilson0805
Message 5 of 5 (266 Views)
10-31-2012 06:47 AM in reply to: Neilw
Thanks Neil
I'll look imto that
John
