Civil 3D Forum
Add a subgrade to a proposed surface
4 REPLIES 4
matttmiles
1011 Views, 4 Replies
I have created an existing surface and a proposed surface and now I need to do a cut/fill comparison but the elevations of the proposed surface are at the top of the pavment and not the bottom of the subgrade. Is there an easy way to add the subgrade to the proposed surface or do I need to go to each spot elevation and drop it 8-12"?
4 REPLIES 4
sboon
in reply to: matttmiles
How did you create this surface - corridor, gradings or some other method?
Steve
Expert Elite Alumnus
neilyj666
For general modelling of construction depths (typically not based on corridors), check out http://ericchappell.blogspot.co.uk/2012/01/magical-way-to-calculate-volumes.html and post back if you have further queries.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
dgordon
create a new surface and paste the proposed surface into it.   now use the surface edit datum tool and drop the proposed surface down to the elevation of the subgrade.    Now compare the newly created surface with the existing surface.
if the volume needed is only within the extent of the roadway, a polygon can be drawn to extract a bounded volume of just the area needed.  good luck to you.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
matttmiles
Thank you all. I created the surface using elevation points. I realize I should have used feature lines but there is some odd geometry and its a pretty large site. I'm going to give it a try today and hopefully see some success 🙂
Rail Community
