I am trying to force the plotstamp variable on for each dwg opened/created. I placed this in my acaddoc.lsp file,
(command "-plotstamp" "On" "")
and it does not work.
I then tried this w/o success.
Do I have somethig wrong with the syntax or does this not work in acaddoc.lsp?
John Mayo
Solved by rkmcswain. Go to Solution.
When you call the (command) function in a startup lisp routine, it has to be inside of the (s::startup) function, which is executed after AutoCAD is initialized.
;;;example (defun-q mystartup () (command "-plotstamp" "_On" "") (princ) ) (setq S::STARTUP (append S::STARTUP mystartup))
