mikepo
Message 1 of 7 (945 Views)
acaddoc.lsp not loading in 2013
945 Views, 6 Replies
11-12-2012 08:44 AM
I have one pc that is not loading the acaddoc.lsp file we have setup company wide.
Several other pc's that have 2013 load the file fine.
I did a find file on the rogue pc and it finds the correct file.
When we start a new drawing on this pc, I get this message:
; error: no function definition: AUTOLOAD
Why would it work on other pc's but not on this one.
The setups were the same on all.
Mike
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
Win 7 Professional - 64-bit
HP Z230
Xeon 3.20Ghz
24GB of RAM
Nvidia GeForce GTX 760
I figured it out!!
For some reason, he was missing the file search path that loaded acad2013doc.lsp
Added that search path and it works fine.
jmayo
Message 2 of 7 (942 Views)
Re: acaddoc.lsp not loading in 2013
11-12-2012 09:21 AM in reply to: mikepo
Is it possible that this rogue PC is finding a different file and perhaps that file has incorrect syntax?
Acad will load the first acaddoc.lsp file it finds. Acad will look in the support folders starting at the top of the list (see attached). If your desired acaddoc file is in a path that is not at the top of the list, acad may be loading an acaddoc file in a secondary support path.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Jeff_M
Message 3 of 7 (937 Views)
11-12-2012 09:26 AM in reply to: mikepo
AUTOLOAD is not a C3D, or AutoCAD, command. This tells me that the acaddoc.lsp has a call to this command which is defined in another custom lisp or dll that is not getting loaded prior to being called.
mikepo
Message 4 of 7 (936 Views)
11-12-2012 09:35 AM in reply to: jmayo
Looked through the complete search paths.
No other acaddoc.lsp that I can find.
I'm going to try deleting lines of the acaddoc.lsp file and see if I can figure out which line is causing the error.
Thanks.
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
HP Z230
Xeon 3.20Ghz
24GB of RAM
mikepo
Message 5 of 7 (935 Views)
11-12-2012 09:37 AM in reply to: Jeff_M
Autoload is a LISP command and it works on all the other 2013 pc's I have installed. (over 30)
Everyone's installation is the same.
I'm going to uninstall the profile and reinstall, then try it again.
Thanks.
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
HP Z230
Xeon 3.20Ghz
24GB of RAM
mikepo
Message 6 of 7 (912 Views)
11-12-2012 01:02 PM in reply to: mikepo
I figured it out!!
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
HP Z230
Xeon 3.20Ghz
24GB of RAM
neilyj
Message 7 of 7 (903 Views)
11-12-2012 01:41 PM in reply to: mikepo
mikepo wrote:
I figured it out!!
acad2013doc.lsp is a very different file from acaddoc.lsp
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
