Civil 3D Forum
acaddoc.lsp not loading in 2013
6 REPLIES 6
CADmgrMike
1583 Views, 6 Replies
I have one pc that is not loading the acaddoc.lsp file we have setup company wide.
Several other pc's that have 2013 load the file fine.
I did a find file on the rogue pc and it finds the correct file.
When we start a new drawing on this pc, I get this message:
; error: no function definition: AUTOLOAD
Why would it work on other pc's but not on this one.
The setups were the same on all.
Mike
Mike Porter
https://provostandpritchard.com/
6 REPLIES 6
jmayo-EE
in reply to: CADmgrMike
Is it possible that this rogue PC is finding a different file and perhaps that file has incorrect syntax?
Acad will load the first acaddoc.lsp file it finds. Acad will look in the support folders starting at the top of the list (see attached). If your desired acaddoc file is in a path that is not at the top of the list, acad may be loading an acaddoc file in a secondary support path.
John Mayo
Jeff_M
AUTOLOAD is not a C3D, or AutoCAD, command. This tells me that the acaddoc.lsp has a call to this command which is defined in another custom lisp or dll that is not getting loaded prior to being called.
CADmgrMike
in reply to: jmayo-EE
Looked through the complete search paths.
No other acaddoc.lsp that I can find.
I'm going to try deleting lines of the acaddoc.lsp file and see if I can figure out which line is causing the error.
Thanks.
Mike Porter
CADmgrMike
in reply to: Jeff_M
Autoload is a LISP command and it works on all the other 2013 pc's I have installed. (over 30)
Everyone's installation is the same.
I'm going to uninstall the profile and reinstall, then try it again.
Thanks.
Mike Porter
CADmgrMike
I figured it out!!
For some reason, he was missing the file search path that loaded acad2013doc.lsp
Added that search path and it works fine.
Mike Porter
neilyj666
@CADmgrMike wrote:
I figured it out!!
acad2013doc.lsp is a very different file from acaddoc.lsp
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
