I am trying to build a proposed surface and an existing surface in the same area. I drew the area as a polyline, created feature lines from the polylines, edited the elevations of the feature lines, and added the feature lines to the surfaces as breaklines. I created the existing surface first. Beginning the process for the proposed surface, when I changed the elevation of the new feature line I added on top of the other one, the existing surface changed. How can I draw two surfaces on top of each other without affecting the other?
Solved by Jay_B. Go to Solution.
It sounds like it may be that you have everythig in the same SITE?
If you don't want the Proposed Surface entities reacting with the Existing Surface entities, keep them in 2 separate SITES.
Are you refering to different drawings being xref'd in? My end goal is to find volumes between the two. Will that work if they are xref's?
No, nothing to do with Xref's.
If the Feature Lines for the proposed and existing surfaces belong to the same site they could be causing conflicts with each other.
See Sites and Site Charactersitics for more information.
In the step above. How did you create the "new" feature lines?
Allen
Allen Jessup
CAD Manager - Designer
After I had finished the "existing" surface completely, I drew a polyline on the same boundary with the verticies at the locations of the proposed elevations. I then converted that Pline to a feature line using "Feature Line from Objects". I then began editing the elevations at each vertex and that is when the "existing" surface began changing.
Create a New Site and using the "Move to Site" command, move all Feature Lines for the Existing or Proposed to the new Site.
Keep the Proposed and Existing in different Sites by first creating another site.
Toolspace > Prospector > Right on click Sites > New >
Then use Move to Site.
You've correctly selected the answer. I just wanted to be sure that you hadn't started by copying the existing featurelines. That can cause some strange results.
While drawing Polylines first isn't incorrect. Drawing featurelines at elevation will save you quite a few steps.
Allen
Allen Jessup
