Civil 3D Forum
A very basic question about surfaces
11 REPLIES 11
Message 1 of 12
karlkarpuk
835 Views, 11 Replies
Hello.
I am trying to learn the Civil 3D, but it is more complicated than i thought. Signed in for some lessons, but until then, i am trying to learn it on my own.
I want to draw a river bed out of nothing. Then draw the water surface. Then find the volume of water in given river.
Where should i start and what should i keep in mind?
Is it possible to just draw the river bed and make a TIN surface out of it using 3Dfaces, then do the same with water surface and then find the volume between those two surfaces?
Or am i missing something very basic?
EDIT: I understand this may be too much to explain through the forum, but if i could get any hints what to search for in google, i would appreciate it.
11 REPLIES 11
Message 2 of 12
in reply to: karlkarpuk
What software have you used before? It will help to know where you are coming from.
Surfaces can be built from a number of different sources. Points, feature/break line, corridors, grading objects. I think it would be good to search out tuturials and use the help docs to start getting a feel for civil 3d.
Message 3 of 12
AllenJessup
About the easiest way would be to draw 4 to 6 featurelines representing the top of bank and the stream channel. Then use 2 featurelines along the bank to represent the water surface. Make a surface out of each set of featurelines and get the volume between them.
Corridor modeling is the most advanced way to do something like this. You'd create an alignment and profile for the centerline of the river and apply assemblies to create the cross sections to model the river.
Most modeling of existing rivers would be done using ground Survey. Point or Points plus surface from aerials or Iliad. But I understand this is a learning exercise.
Allen Jessup
CAD Manager - Designer
Message 4 of 12
troma
Basic answer: yes, you can do that.
Personally, I would use feature lines.  But as mentioned, you have options.
I also recommend the tutorials.  If you go through them all, even if irrelevant ones, you get a good overall idea of the scope of the program, and an idea of what you need to focus on afterwards.  I never had any official 'lessons', just the tutorials and a coworker who was learning the program 6 months ahead of me (but had a good LDT background).  I'm not saying don't get lessons, I'm just saying that the tutorials will help.
Mark Green
Working on Civil 3D in Canada
Message 5 of 12
AllenJessup
See if any ot THESE help.
Allen Jessup
Message 6 of 12
karlkarpuk
Alright! I did go throught SOME tutorials involving surfaces but there are very many and i wanted to start with simpler tasks that i made up for myself to get comfortable with those first.
I now know to take up feature lines and corridors next.
Thank you!
Message 7 of 12
autoMick
Here's another thread with some other approaches: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/River-bottom-surface-from-3dpolyline-sections/td-p/36...
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 8 of 12
AllenJessup
Now to go to the far end of the scale. The attached is a Model of the bed of the Hudson River between Rockland and Westchester counties. I created it from benthic data (sidescan sonar) downloaded from our state GIS ClearingHouse. The project was to determine the Thalweg (deep channel) that marks the county boundary.
Allen Jessup
Message 9 of 12
BrianHailey
in reply to: AllenJessup
Kudos for using the word Thalweg. That's got to be one of my favorite words!
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 12
AllenJessup
I didn't know it until I had to determine one. My research on boundaries turned it up. Now I even know that the original pronunciation would be Thallveg.
The real problem is trying to explain it to people who see the County Line on a map and try to say that it's wrong because the line is the "Center" of the river. I tell them to read the legal case about the ownership of Ellis Island.
The weird thing is that he boundary between New York and New Jersey is different depending if you're talking about the surface of the water or the bed of the river. On the surface it's the high water mark on the New Jersey shore. On the bed of the river it's the thalweg. The Ellis Island case hinged on the fact that most of the island is fill. You can't change a water boundary by filling. So NY has the jurisdiction on the original island that was above water while NJ has jurisdiction over the filled portion which would still be considered part of the river bed.
Why do I know these things? Because people keep ASKING!!Smiley Surprised
Allen Jessup
Message 11 of 12
neilyj666
interesting explanation about Ellis island but you should get out more...Smiley Wink
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 12 of 12
AllenJessup
in reply to: neilyj666
Hi Neil,
I've been off for a while and just starting to catch up. So I did get out more. Smiley Happy
This is actually stuff that I had to learn for work. Our office is responsible for doing on ground location of the County, Town and Village lines. Since one of our County borders is also the State border we get involved with that too.
I also get asked questions like; Which of our County Roads existed before the revolution? So I study early 18th century history and mapping. That get me involved in the W3R project.
Allen Jessup
Rail Community
