There's the Match Property tool "Matchprop" is the command.
If you use a typical Autocad workflow then most of your drafting is done with symbology set to BYLAYER attributes. In that case all you need to do is set the layer of the object you want to match to "current". Then all your subsequent drafting will match and you won't need to keep using the Match Properties tool.
To set the the layer of an object current, pick the object, then type the LAYMCUR command. The LAYMCUR command is also available as a button on the Layer toolbar.
