Hello again,
I am still needing some help on this. I am getting multiple errors at each section in the event viewer. The error reads as follows:
10+55.31': Target object not found
Outside Elevation
Offset: 13.00'
Elevation: 1463.17'
Corridor: 199th Street West
Baseline: 199th St W
Alignment: 199th St W
Profile: FGLayout
Assembly: 199th-Main
Assembly Baseline:
Subassembly Group: Right
Local Subassembly Name: Gravel Shoulder
Global Subassembly Name: Shoulder-Right
Assembly: C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2008\enu\C3DStockSubassemblies.dll
.Net Class: Subassembly.ShapeTrapezoidal
Source: ShapeTrapezoidal
It seems that the trapezoidal sub-assembly might be the reason for the error but I am not sure. I am not stretching the pavement at this area and 13' happens to be the default width where the shoulder (trapezoidal) attaches.
Does someone have an example using the trapezoidal of what the points and links could be set to? I know someone is going to say set them to anything you want, but I am getting all the errors so I have apparently done something wrong.
Thank you,
Daryl Standrich
