Civil 3D Forum
A COGO point Z modification does nothing with surface out of date???
5 REPLIES 5
tonnot
312 Views, 5 Replies
Hello i have a problem (a bug?)
I have a point group used in a surface.
I click on a point, change its Z and .... nothing more ocurrs.
I have to click on surface, context - surface properties, click on accept and then ... yes the surface is now  showing the out of date .
What is happend ? Thanks.
Civil 3D (2013) how much you have to improve....
5 REPLIES 5
Jay_B
in reply to: tonnot
If you modify a point belonging to a point group used in the surface definition the "Point Group" containing the modified point must be updated before updating the surface.
Prospector>Point Groups heading>Rt Click>update (This will update all point groups at once.)
C3d has no means of Automatic "Point Group" update out of the box.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Jeff_M
in reply to: tonnot
How are you editing the Z? If I just edit the elevation in the Properties dialog, I see the same thing you do and I need to update the PointGroup. However, if I select a point, right-click, choose Datum, then raise/lower the point by whatever amount to get the desired elevation, the surface updates immediately.
Jeff_M, also a frequent Swamper
tonnot
in reply to: Jeff_M
U fffff
Both are right....
But what a unreliable behaviour, isn't it ?
neilyj666
in reply to: tonnot
Ahhhhh....the wonderful pseudo dynamic behaviour of Civil 3D...:)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jay_B
in reply to: tonnot
The post marked as "Accepted Solution" has nothing to do with a solution to the problem in the Original Post.
C3D 2018.1
C3D 2016 SP4
Rail Community
