Hello i have a problem (a bug?)
I have a point group used in a surface.
I click on a point, change its Z and .... nothing more ocurrs.
I have to click on surface, context - surface properties, click on accept and then ... yes the surface is now showing the out of date .
What is happend ? Thanks.
Civil 3D (2013) how much you have to improve....
Solved by neilyj666. Go to Solution.
If you modify a point belonging to a point group used in the surface definition the "Point Group" containing the modified point must be updated before updating the surface.
Prospector>Point Groups heading>Rt Click>update (This will update all point groups at once.)
C3d has no means of Automatic "Point Group" update out of the box.
How are you editing the Z? If I just edit the elevation in the Properties dialog, I see the same thing you do and I need to update the PointGroup. However, if I select a point, right-click, choose Datum, then raise/lower the point by whatever amount to get the desired elevation, the surface updates immediately.
U fffff
Both are right....
But what a unreliable behaviour, isn't it ?
The post marked as "Accepted Solution" has nothing to do with a solution to the problem in the Original Post.
