I have a surface style (standard deviation) for contour with a range of 7 classes.
Ok, if I apply this to my surface (it is a fine built surface) I have only three intervals
Whats can be happen ?
Civil 3D (2013) how much you have to improve....
did you goto the analysis tab of the surface properties and sample the ranges?
I have always 3 ranges...
Even If I write 7 and click on run analisys I get 3 ranges....
I'm using contour ranges option.
Maybe I'm using something without sense?
Thanks !
I don't generally use the contour analysis, but i'm guessing that if my surface is set to show contours ever 1ft and my surface has a min elevation of 770.50 and a max elevation of 773.50 I might expect to only get 3 ranges since my surface only contains around 3 vertical feet of information.
I have heights from 0 to 16 meters.
I'm using this :
I set up a surface similar to yours and I now understand what you're seeing.
the only way I was able to get the analysis tab to sample 7 different elevations was to use the quantile type.
here is the descriptions of each type from acad help.
I hope this helps.
