Darienas,
Bad luck, there are ony 4 pavement layers in the example subassemblies.
To reproduce everything they do but with an added layer you could customise
an existing subassembly.
Could you send some examples/drawings or sketches of what yo need to achieve
so I can give you a more detailed advise?
In the meantime, I think you could use two features to achieve pretty much
anything:
1. Check out under "General" area of the Subassemblies and specially the use
of Links and Marker Point subassemblies
2. Check the help file for how to create subassemblies from polylines
HTH
Rad
"Darienas" wrote in message
news:4875286@discussion.autodesk.com...
Hi all
I ahev a problem, when I traing make my road construction, in library is
just some tipical variants like CarriagewayOutsideSuper or els, but it not
imposiple to create my construction, I dont' n know mabye in other countryes
there is ewerything what you need, but to me is just small part of imposible
variants, wich use roads desingers,
Mabye is the way to make construction elements, or mabye is the library
upgrade or somethink, becouse now I can make my road construction and I
can't calculate earth work's, I can use just aligment and profile creation
Darius
