C3DR14
I'm pretty sure I can replace my cogo point marker with a 3d tree that I can see in the object viewer using the realistic style and print out. Problem is where is that 3d block of the trees?
Not sure if this helps but the default symbols can be found here:
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Symbols\
Thanks but those are only in 2D. I think there are some 3d tree blocks that will display in elevation in the object viewer.
Your path may be slightly different. But -
C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\x64\en-US\C3D\AllUsersContent\Data\Symbols\Mvblocks OOPS. That's the instalation directory. Try:
C:\ProgramData\Autodesk\C3D 2012\enu\Data\Symbols\Mvblocks\
Allen Jessup
Allen Jessup
CAD Manager - Designer
