Civil 3D Forum
3d polylines to 2d polylines
14 REPLIES 14
Message 1 of 15
873 Views, 14 Replies
Is there a way to convert multiple 3d polylines to 2d polylines? I know how to convert them one at a time through feature lines but not all at once. I am looking for a command similar to 3dpolylines/Convert to 2d polylines in LDD.
Casey
14 REPLIES 14
Message 2 of 15
I could be totally off base here, but can't you just explode them. I know that that is a bad word in Civil 3D but...
Let me know,
Melanie Santer
L.A. CAD
Message 3 of 15
nzeeben
Grading Menu->Polyline Utilities-> Convert 3D polylines to 2D polylines.
Nick Zeeben
Engineered Efficiency
C3D 2007 SP1a
XP Tablet and Pro
wrote in message news:5253995@discussion.autodesk.com...
LDD.
Casey
Message 4 of 15
If you explode a 3d polyline it turns into a bunch of lines with elevation. I am trying to mimic the LDD command to convert a number of 3d polys to 2d.
Thanks for the reply
Message 5 of 15
Civil 3d 2007?
Message 6 of 15
Hello Casey,
From the "Grading" menu pulldown select "Polyline Utilities" > "Convert 3D
to 2D Polylines".
The new 2D polylines will have the elevation of the start elevation of the
3D polyline.
Angel C. Espinoza
KETIV Technologies
Angel's Civil 3D Thoughts
http://acecivil3d.blogspot.com/
LDD.
Casey
Message 7 of 15
nzeeben
Yes.
wrote in message news:5254040@discussion.autodesk.com...
Civil 3d 2007?
Message 8 of 15
By the way, Connie B suggested that we run an AUDIT after using the these
Polyline conversion Utilities. JIC.
Good tip!
Angel C. Espinoza
KETIV Technologies
Message 9 of 15
Hi
If you have the Express tools installed, select your 3d Polylines and go Experss Tools - modify -Flatten objects, this sets all elevations to zero, but leaves the polylines as 3d polylines though. It depends on what you are trying to achieve.
Message 10 of 15
Oh, come to think of it, Map cleanup utility will also convert 3D poly's
into 2D.
wrote in message news:5254208@discussion.autodesk.com...
Hi
trying to achieve.
Message 11 of 15
Angel is there a method to have them acquire an elevation of Zero, along the
lines of LDT's tool?
Of course if I had kept reading, I might have found the answer to my query
Real Soon Now. 😉
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4
AMD Athlon 64 X2 Dual-Core 3800+ 2.01GHz
XP-Pro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
"The only Constant is Change".
"Angel Espinoza" wrote in message
news:5254046@discussion.autodesk.com...
Hello Casey,
to 2D Polylines".
3D polyline.
Angel C. Espinoza
KETIV Technologies
LDD.
Casey
Message 12 of 15
In LDT I redefined the Plot command Angel - with some help of course:
snip from MNL file>
(princ "Redefining PLOT command with User extensions.")
(command "undefine" "plot")
(defun c:plot ()
(command "qsave")
(command "regen")
(command "AUDIT" "Y")
(command "LTSCALE" "1")
(command "qsave")
(command "spell" "all" "")
(initdia)
(command "_.plot")
(princ)
end of snip>
So would some along those lines be possible nowadays with the CUI, in
regards to including a Audit after the conversion has processed?
Yes I know it's Lisp. 😉
Don Reichle
LDT/CD-2K4
XP-Pro 32bit SP2
2GB RAM
news:5254088@discussion.autodesk.com...
Good tip!
Angel C. Espinoza
KETIV Technologies
Message 13 of 15
>"Don Reichle" wrote in message
> >news:5255774@discussion.autodesk.com...
>the lines of LDT's tool?
Doesn't LDT's 'convert to 2D polyline' put the newly created 2D polylines to
zero elevation automatically?
Message 14 of 15
Hi Connie,
From memory, it asks you to assign a level, but defaults to 0.
Laurie Comerford
CADApps
www.cadapps.com.au
"Connie B" wrote in message
news:5256661@discussion.autodesk.com...
Message 15 of 15
Yeah, I would have worn I rememberd it the same way.
Tha's why I found Don's quetion slightly puzzling. of course not enough to
fire up LDDT and check it out.
Oh well.
"Laurie Comerford" wrote in message
news:5257068@discussion.autodesk.com...
Hi Connie,
Rail Community
