Ok, thanks for the responses. I'm fortunate enough to have a dual monitor
setup so when I have the need to use the 3D polyline features, I usually
have Land Desktop active on one monitor and Civil 3D open on the other.
Then just do copy and paste between the two. But I know there has got to be
a better way.
Dave
"Jon Rizzo" wrote in message
news:4912174@discussion.autodesk.com...
The Autodesk folks are aware of this need, so these tools will will probably
show up in a future version. That said, you can actually do quite a bit of
grading without them. Just convert a 2D polyline to a grading feature line,
and use the Elevation Editor to set elevations and grades along it. The
biggest limitation I see to doing this is that the elevation editor does not
give you any visual indicator to show you which control point you are
currently editing, so if you have a feature line with more than 4 or 5 of
them, it gets pretty confusing...
Hope this helps,
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
wrote in message news:4911772@discussion.autodesk.com...
Is any reasson to this 3d polyline commands doesnt exists in civil3d
2005/2006???? Thanks, Joao.
