Hey all,
I'm working with a simple surface in two vertical viewports. I'm viewing one in 2d Wireframe and the other in 3D. I noticed the contours don't stay on in the 3d view. All I see are the triangles, no contours with them. Is there a quick fix to view them in 3D?
Thanks!
Solved by Jeff_M. Go to Solution.
Yes. In the 2d view, the surface just has on 1 and 5 foot contours with no triangulation. But in the 3d view, you can only see the surface as triangles, even though the surface is set to those contour intervals.
Is there a setting somewhere to control surfaces when in 3d view?
