Civil 3D Forum
3d max design tutorial
10 REPLIES 10
Message 1 of 11
KINGDAVID2
642 Views, 10 Replies
i need help on how to use 3d max design for road modelling, in need a step by step tutorials on the subject
10 REPLIES 10
Message 2 of 11
ToddRogers-WPM
in reply to: KINGDAVID2
Go to the 3ds Max forum or YouTube.
Todd Rogers
Message 3 of 11
KINGDAVID2
in reply to: ToddRogers-WPM
Thanks, i will try that
Message 4 of 11
neilyj666
Do you have Civil 3D, if so then it is designed for this task?
3ds Max is not designed for this, have you tried Infraworks?
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&ved=0CEgQtwIwAg&url=http%3A...
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 11
ToddRogers-WPM
in reply to: neilyj666
You can use the Civil View extension for 3ds Max.  It's only for visualization though.  No design purposes.
Todd Rogers
Message 6 of 11
KINGDAVID2
Thanks for your reply, i use Civil3d for my road design am intrested in 3d max design for 3d modeling of my road design but dont know how to go about it so i need a comprehensive and step by step white paper or manual to use especially on road modeling aspect of the software
Message 7 of 11
ToddRogers-WPM
You will use the Output tab of the ribbon in Civil 3D and select Export to Civil View for 3ds Max Design.  Then in Max, you will import the file created into Max and it will execute the Civil View exension in Max.
http://www.youtube.com/watch?v=O0q2lhrLdoo&list=PL565028A96592A24F
Todd Rogers
Message 8 of 11
KINGDAVID2
thanks for your reply but i prefer a paper tutorial to study and practice the work, if i can get any  one instead of the youtube video i will appreciate it
Message 9 of 11
ToddRogers-WPM
Here you go.  Handouts, powerpoint and video for you...
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2012/autodesk-3ds-max-design/autoca...
Todd Rogers
Message 10 of 11
KINGDAVID2
Thanks so much so much, i got it and believe it will help me
Message 11 of 11
neilyj666
the civil view extension is more for visualising data that has already been modelled in civil3d, I'd suggest you wouldn't want to be modelling this sort of thing in Max but for animations Max is ok although I'd also consider Infraworks for flythroughs google hydrolectric dam china infraworks
Rail Community
