Active Member
S_G_I
Message 1 of 21 (448 Views)
3D Face - Solid
448 Views, 20 Replies
02-27-2013 11:17 PM
I want to show the topography of the surface I created.
A long time ago I changed some definitions and succeeded - see the attached picture.
The problem is I don't remember what I did :smileysad:
I think last time I found a button somewhere to switch to 3D view/model and then
the 3D Faces were suddenly displayed as semi-solids.
Could somebody please help me?
Thanks a lot,
S_G_I
There are many ways to get that, for instance:
_-VIEW => _NEISO
_SHADEMODE and choose one of the types
antoniovinci
Message 2 of 21 (431 Views)
Re: 3D Face - Solid
02-28-2013 01:19 AM in reply to: S_G_I
_-VIEW => _NEISO
neilyj
Message 3 of 21 (420 Views)
Re: 3D Face - Solid
02-28-2013 03:14 AM in reply to: S_G_I
Take a look at this blog post http://civilforautocad.blogspot.co.uk/2011/05/civil-3d-2012-little-things-part-two.html
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
AllenJessup
Message 4 of 21 (415 Views)
Re: 3D Face - Solid
02-28-2013 04:33 AM in reply to: S_G_I
First you have to have a Surface Style that displays triangles in the Model. From your image it looks like you'd want to set a Conceptual visual style. Then use 3D orbit or any other method of viewing it in 3D.
antoniovinci
Message 5 of 21 (407 Views)
Re: 3D Face - Solid
02-28-2013 04:43 AM in reply to: AllenJessup
Dear Allen,
you don't really need to do that.
Whatever the style, when you turn on a ISO view, Autocad shows itself in a TIN fashion, as you can see in this Map2006 screenshot:
Joe-Bouza
Message 6 of 21 (405 Views)
Re: 3D Face - Solid
02-28-2013 04:47 AM in reply to: S_G_I
Here is a graphic of what the other folks are describing. Granted my relief is not that pronounced
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
AllenJessup
Message 7 of 21 (399 Views)
Re: 3D Face - Solid
02-28-2013 04:55 AM in reply to: antoniovinci
Yes Antonio. You really do. In Civil 3D you need to have the triangles on. If they are off
Then all you will see is contours in 3D
antoniovinci
Message 8 of 21 (397 Views)
Re: 3D Face - Solid
02-28-2013 04:59 AM in reply to: AllenJessup
Got it, Allen, but my Map works as I described, and I'm surprised that Civil needs to change the style...
neilyj
Message 9 of 21 (394 Views)
Re: 3D Face - Solid
02-28-2013 05:03 AM in reply to: antoniovinci
As I have said many times before the Map that comes with Civil isn't quite the same as the boxed standalone version of Map - MapLT?
neilyj
AllenJessup
Message 10 of 21 (389 Views)
Re: 3D Face - Solid
02-28-2013 05:11 AM in reply to: antoniovinci
It's an attempt to let the user set it up as they need. Sometimes you want to see the surface and sometimes you don't Civil styles are very different from Map or Autocad. Very powerful, very complicated.
