Civil 3D Forum
3D Excavation Animation
9 REPLIES 9
Message 1 of 10
Geodetic20
668 Views, 9 Replies
Good day everyone
I was wondering if it was possible for Civil 3D to animate excavation by using two surfaces, one before and one after, or at least something similar to what I've mentioned
9 REPLIES 9
Message 2 of 10
neilyj666
in reply to: Geodetic20
Don't think this can be done in Civil 3D but perhaps can be in 3ds Max
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 10
Geodetic20
in reply to: neilyj666
I see. I really hoped that Civil 3D can animate the base surface morphing into the excavated surface
Message 4 of 10
neilyj666
No I don't believe it can (this is the type of thing I need to do as well) but perhaps others will suggest a method.
You could perhaps do something manual with surface transparencies (if using 2012 or 2014), isometric views and screenshots and put them in Powerpoint as a slideshow?
Message 5 of 10
Geodetic20
I was hoping I wouldn't have to resort to "brute force" methods. Just to clarify, are 3DS Max and 3DS Max Design the same because I only have 3DS Max Design
Message 6 of 10
neilyj666
They are slightly different but Max Design (part of IDSP) is the one required.
Not sure how/if it can be done though so would be interested in if you manage to do it
Message 7 of 10
Joe-Bouza
I think you will need the intermdeiate surfaces to get a video
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 8 of 10
Geodetic20
in reply to: Joe-Bouza
What exactly do you mean by this sir? I'm new to Civil 3D and and completely new to 3DS Max Design
Message 9 of 10
neilyj666
I was thinking along the lines of existing surface 0% transparent, proposed 100% transparent then lowering the existing transparency and increasing the proposed in increments ending up with the proposed only.
This is just "typing out loud" I've no idea if this is possible in 3ds Max design and even if it is I've no idea how to do it
Message 10 of 10
Have a look into the autocad command anipath.
This allows you to create animations along a polyline etc. It can output WMV, AVI, MOV and MPG from 320x240 up to 1024x768
You could create an animation of one surface and then create another animation with the other surface along the identical path, then using movie maker you can fade one into the other with the path being identical, you should see one surface fade out as the other fades in.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
