Civil 3D Forum
3D Curve
6 REPLIES 6
rkk_engineer
783 Views, 6 Replies
3D Curve
How do I draw a 3-d curve in Civil 3D?  I have a curved alignment that has a horizontal curve and is also curved in the vertical direction.  I'm not sure how to draw this.  Can somebody help me?  Thank you
6 REPLIES 6
Sinc
in reply to: rkk_engineer
If you're using Alignments, the vertical is defined using a Profile.
You can also use Feature Lines, which are a bit like a "light-weight Alignment", but those cannot have vertical curves.  A Feature Line can have a true horizontal curve, but as opposed to a Profile, a Feature Line can only straight-grade from grade break to grade break.
By contrast, a 3D Polyline cannot have curves in either horizontal or vertical directions, and all curves must be approximated using a series of short line segments.
Sinc
civilspace
*if* you needed a literal 3D curve, Sinc is right, you would need to approximate it using a series of segments.  The best way would be an alignment for the horizontal, profile for vertical, subassembly, corridor with a high frequency, extract a feature line from that.
Anthony
mathewkol
You can have a 3D curve, but it can't be an alignment/profile combination.  For example, you would create a feature line that is curved, you would have different elevations at each end of that curve...there is your 3d curve.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
OMCUSNR
I'm thinking you'll need to run a cooridor, create a surface, then view it in 3d view.  You'd be able to see the resulting centerline that way.
Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
civilspace
in reply to: OMCUSNR
I love it - 4 people saying the same thing.
Anthony
rkk_engineer
in reply to: civilspace
thanks for your input
Rail Community
