Sorry if this has been posted before (although I couldn't find anything).
We're now running C3D 2010 on Windows 7 64bit and I'm told by our 'IT guy' that the CAD installations are also 64 bit. I'm not sure they are because I get memory and performance issues even though I have 8Gb, and when I run task manager it shows the running process as 'acad.exe *32' as in the attached image.
So, how do I determine if I'm running C3d 64 bit or not?
Cheers,
Kevin
Solved by Sinc. Go to Solution.
There is no 64-bit version of Civil 3D 2010. C3D 2011 is the first release with a 64-bit version.
Your IT guy is probably talking about a 64-bit deployment package, which makes the IT guy's job easier for installation. However, that is merely a special installation package, designed to install C3D on a 64-bit OS. The program itself is still 32-bit.
Civil 3d was not available as a 64 bit program until 2011. If you are using 2010, it's a 32 bit insatll. HOWEVER, plain autocad in 2010 was available as a 64bit program.
I installed my 2010, in 7 64pro, with the XP emulation.
Reid
Thanks guys, that all makes sense.
We're about to move up to 2011 anyway so I'll make sure he does the 64bit one.
Another thing - will I notice any performance increases moving up to 2011, either because of the 64bit-ness or because 2011 is a little more optimised?
Kevin.
With SP1 installed 2011 seems to be a bit more stable, and has fewer crashes due to "out of memory" problems. If you're on subscription, there's a new bonus pack too.
Reid
When you make your move, you need to make sure if use any third party applications that they also have a 64bit version.
Good point! Case in point Bentley SewerCAD and WaterCAD are only 32-bit plugins for Civil3D; does not work on 2011 64-bit. (this has been discussed in other threads).
