I've noticed that with 2015 when a Mr. Sid aerial is placed in the drawing (using MAPIINSERT) that the new command previews cause the cursor to become sluggish. For example, with an image on and I have two lines that I want to fillet, when the new preview of what the fillet will look like tries to load, the cursor jerks and is extremely slow to respond. This happens with any of the new previews, such as trim, extend, fillet, etc. As soon as I turn off the image the previews work just like normal with no slow down at all. When this happens it is very frustrating just to trim a line because the cursor gets stuck for a second whenever I try to get the cursor to select the trim objects. When the cursor is moved to select the trim object(s), whatever lines the cursor passes over there is a 1 second lag, which means when the cursor is moved across just two lines there is a pause for each one for a second.
Does anyone else run into this issue? I thought it might be the video drivers for my NVIDIA Quadro 2000, so I loaded the latest recommended certified driver (331.82) and it still does it.
Have you tried turning off Hardware Acceleration?
and your video card is listed as certified here:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Could this be from only 6 GB RAM? That seems more that a little low for Civil3D work, let alone large image files.
@dgorsman wrote:Could this be from only 6 GB RAM? That seems more that a little low for Civil3D work, let alone large image files.
Considering acad.exe is only using 850MB of memory with two drawings open right now, no, it's not a problem. Civil 3D rarely ever uses more than 2.5GB even though it's 64-bit and most of the time with mutliple drawings open it only takes up 1.5GB. I looked a bit more at this and noticed that when the image is on and the cursor is moved over an object that the preview tries to show, acad.exe spikes to 100% of a core, which is why I'm almost positive it's not a graphics card issue.
I am having this problem too, to the point where I can't even do the simple commands without waiting for several minutes for my screen to unfreeze. (the bigger and more complicated the polyline, the worse it seems to be. Bad news for grading object daylights...) How do you turn off the command previews?
@ACADuser wrote:
Have you tried setting IMAGEQUALITY to "draft"? I would be interested in knowing if there is a workaround other than turning the image off. I don't have 2015 installed, but if possible you could try turning off the preview functionality.
This is still a known bug that C3D SP1 did not fix. There is no workaround other than either turning off the image or turning off all command previews, neither of which is a good solution.
