Civil 3D Forum
2015 Object Properties Display (2)... what is this?
5 REPLIES 5
kbarnettza
1166 Views, 5 Replies
Civil 3D 2015
Could be Map 2015
Not AutoCAD 2015
The Properties palette has an aditional tab: Display (2)
Object control by display system ?  What is this? How does it work? Will it make my life extremely better?
5 REPLIES 5
Not seeing that on my 2015, only the other 4 tabs. Do you have any custom software loading along with C3D?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
: (   no .. nothing additional installed.. except .. Country kits for ANZ and UKIE
This tab even appears in DWG's started using no template ...
Wierd!!
rkmcswain
in reply to: kbarnettza
.....and I'm still trying to figure out what the regular "Display" tab is for... not to mention the "Object Class" tab....
neilyj666
in reply to: rkmcswain
I'll second that...:)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Murph_Map
Both of them are used in Map3d, the display tab is used for differnt maps create in the single dwg.The object class is for classified objects. Well I better say that's WHAT they used to be for.
Murph
Supporting the troops daily.
Rail Community
