I think I found a bug in C3d 2114. Here is what I've done. Started a new survey database using the default setting, then I go to that data base and edit survey database setting. I then change the setting to my local coordinate zone then I export setting to a file. I then go the Survey User Settings and set the Survey Database Settings to look at that file. Then I try to create a new survey database and the program crashes. If I go and delete the file I created that saved the setting it will work again but it goes back to the default setting of no coordinate zone set. I have tried saving the setting to both local and network drives and it crashed every time when there is a file there for it to look at while creating a new survey data base.
Hi Terry,
Could you please open a case with all the relevant files attached along with the steps to replicate the issue?
Here is the case number Case 08435342 - Survey Database. I think he aready closed it.
Just installed Civil 3D 2014 and we are having the same problem. As soon as we create a Survey Database Setting file and then create a new survey database the program fails.
Did AutoDesk ever come up with a fix for this problem? We've only succeeded in isolating the cause ...which seems to be the Survey Database Settings file.
Have you installed the Service Pack? It has a number of fixes for the Survey portion.
Thank your Jeff for your response. I just installed SP1 for C3D 2014 and it does fix the Survey database problem.
Darn shame the couldn't fix the survey figure properties bug that they broke as well.
Rick Jackson
Survey CAD Technician VI
