Civil 3D Forum
2014 River analysis
4 REPLIES 4
299 Views, 4 Replies
2014 River analysis
When trying to pick reach lenghts where object is an arc, the result show a tangent to the arc?
Need help
4 REPLIES 4
jmayo-EE
With some applications I need polylines from these lines and curves. I then use the Create 3D polyline from 2D polyline command,..then the Create 2d polyline from 3d polyline command to convert the pline back with the curves broken into chords. I will then use the Weed FeatureLine command to remove as many vertices.
After all that I typically get geometry that converts and measure better for Hec Ras.
John Mayo
jmayo-EE
in reply to: jmayo-EE
Replace the first 'need' above with 'create' so it reads better. 😮
John Mayo
Thanks John. I won't get to it until Friday, but will let you know.
John:
It worked. I guess that's why you are the "expert elite"!
BTW is there any publication that is more detailed than the 2014 user's guide? I am fairly proficient in Civil 3D and long time user of HECRAS. The trouble Im having is marrying the two. (Would settle for an engagement).
For instance, when I am inputing Bridge data, I want to input road data. I am user EG sutface to cut stations--is there any way to cut road an have it automatically entered? When using "Draw Road it says "pick". Pick from what? All I have is the downstream section I extracted from surface.
**** Schneider, P.E.
Project Manager
KAPUR & ASSOCIATES, INC.
10101 Market Street, Ste C20, Rothschild, Wisconsin 54474
main 715-359-9668 Ext. 4005 | fax 715-359-4844 | cell 715-573-1269
www.kapurengineers.com
Rail Community
