rkmcswain
Message 1 of 23 (1,507 Views)
2014 Pipe network: pipe styles change with Sync
1507 Views, 22 Replies
12-30-2013 09:09 AM
Using 2014 SP1, we have “Parent” drawing and “Child” drawing, both were started from the same template. Parent contains a pipe network, with a data shortcut created for it.
We open “Child” drawing and d-ref in this pipe network, taking care to select the proper Parts List – and everything looks great.  But, the first time we sync the pipe network, the style assigned to the pipes changes (to something unwanted).
We have:
  • Deleted the pipe network from “Child” and re-referenced it in.
  • Ensured that both drawings are associated to the same project
  • Went back to “Parent” and deleted the d-ref from the list and created it again.
....and nothing works.
Then I open “Child” in 2013 SP2, delete the pipe network, create the d-ref to it again then sync. The styles DO NOT change, and everything is fine.
So what is the difference between 2014 SP1 and 2013 SP2?
Why are the styles changing in 2014 only?
TIA
(FWIW, I have researched a few threads here and at augi regarding the possibility that the two drawings do not share the same parts list, etc. - and have taken care to make sure that is not the cause in this case)
jmayo
Message 2 of 23 (1,493 Views)
Re: 2014 Pipe network: pipe styles change with Sync
12-30-2013 10:23 AM in reply to: rkmcswain
Not that I can answer the 'why' and not that this will help you solve the issue but when you create the DRef are your pipes and structures displaying the same styles they were created in (parent style)? Are the styles being switched to the style that they were created in, the template default, pipe network default or a random style perhaps the first name in the style list?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
rkmcswain
Message 3 of 23 (1,490 Views)
12-30-2013 10:36 AM in reply to: jmayo
jfmayo wrote:
..... when you create the DRef are your pipes and structures displaying the same styles they were created in (parent style)? Are the styles being switched to the style that they were created in, the template default, pipe network default or a random style perhaps the first name in the style list?
(1) Yes, when the dref is created, the pipe (and structures) are exactly like they are in "Parent" drawing. And FWIW, this is how it has always worked for us, 98% of the time. The other 2% of the time can be attributed to when a user starts with the wrong (or no) template.
(2) I think it may be using the default style located here (Settings>Pipe Network>Commands>Create Network>Default Styles>Pipe Default Style) - but I'm not 100% on that. I was thinking it took its "Default" from (Settings>Pipe Network>NetworkName>Edit>Pipes Tab>Style column) and that setting is correct.
I did not mention this in the original post to keep the confusion to a minimum, but I have a second pipe network in both "Parent" and "Child" (which uses a different parts list), and it works fine. No problems syncing at all with this one in 2014.
Thanks for your help!
TRogers
Message 4 of 23 (1,485 Views)
12-30-2013 11:00 AM in reply to: rkmcswain
What about the default styles in the Command Settings?  Are they set to what you want them to be?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Distinguished Contributor
n2itive
Message 5 of 23 (1,480 Views)
12-30-2013 11:16 AM in reply to: rkmcswain
This sounds like a familiar topic so I did a quick search.
Maybe this thread can help: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Pipe-and-structure-styles-resetting-when-data...
Infrastructure Design Suite 2014
Civil 3D 2013 sp2
Windows 7 x 64, 16 GB
Intel Xeon @ 2.80 GHz
NVIDIA Quadro K2000
rkmcswain
Message 6 of 23 (1,467 Views)
12-30-2013 12:29 PM in reply to: TRogers
Todd, it doesn't matter. We are using the same templates/drawings/setting in both 2013 and 2014.
The problem only happens in 2014.
See the thread in post 5 - that pretty much sums it up, the workaround being "do not sync".
My workaround is = quit using 2014 until this is fixed.
rkmcswain
Message 7 of 23 (1,466 Views)
12-30-2013 12:30 PM in reply to: n2itive
Thanks. This tells me the workaround is to not sync, so I will go with my own workaround of just not using 2014.
Thanks again.
TRogers
Message 8 of 23 (1,458 Views)
12-30-2013 01:09 PM in reply to: rkmcswain
I heard that is supposed to be fixed in 2015 Randy.:smileysad:
*Civil 3DJ*
Todd Rogers
Visit my blog here.
jmayo
Message 9 of 23 (1,450 Views)
12-30-2013 01:28 PM in reply to: rkmcswain
Looks like it's an issue...
John Mayo, PE
IDSP 2014
rkmcswain
Message 10 of 23 (1,445 Views)
12-30-2013 01:50 PM in reply to: TRogers
It was fixed in 2013 :-(
