Valued Mentor
gccdaemon
Message 1 of 6 (568 Views)
2013 Scale List in registry
568 Views, 5 Replies
01-28-2013 01:38 PM
Having trouble finding the correct place to put the FEET, INCHES, METRIC, custom scales in the registry. Can anyone help? I'm not sure if its any of the following or is it somewhere else now?
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
[HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
[HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Valued Mentor
gccdaemon
Message 2 of 6 (556 Views)
Re: 2013 Scale List in registry
01-28-2013 03:16 PM in reply to: gccdaemon
Bump
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
Valued Mentor
gccdaemon
Message 3 of 6 (536 Views)
01-29-2013 12:31 PM in reply to: gccdaemon
bump
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
Active Contributor
aluster
Message 4 of 6 (511 Views)
01-30-2013 09:27 AM in reply to: gccdaemon
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Scale List]
This is the location I have. The attached file adds the scales that I need. I found this somewhereon the forum a while ago so I don't know who to give the credit to.
Edit: Autodesk won't let me post the file so I have renamed the extension. Save the .doc to your computer and rename it to .reg then you should be able to run it.
Dell Inspiron 546
8 GB Ram
Win 7 64-bit SP1
Civil 3D 2013 SP1
Valued Mentor
gccdaemon
Message 5 of 6 (500 Views)
01-30-2013 01:26 PM in reply to: aluster
This location was correct for 2012, but it's not working for 2013. I think they changed the override function. When i reset the scale list it puts the default scales in rather than adding the overridden values sent in your file. Hopefully someone from Autodesk chimes in on this, because I have standards i have to deploy.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
Valued Mentor
gccdaemon
Message 6 of 6 (495 Views)
01-30-2013 02:39 PM in reply to: gccdaemon
Figgured it out!!!! On the very first scale, (the "0" grouping) you have to set the scale type to 3. If you don't it doesn't import the custom scale list. YAY ME!
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
