Civil 3D Forum
2013 Scale List in registry
5 REPLIES 5
gccdaemon
880 Views, 5 Replies
Having trouble finding the correct place to put the FEET, INCHES, METRIC, custom scales in the registry. Can anyone help? I'm not sure if its any of the following or is it somewhere else now?
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
[HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
[HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B000:409\
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\AEC\7.0\AecBase70\Scales\
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
5 REPLIES 5
gccdaemon
in reply to: gccdaemon
Bump
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
gccdaemon
bump
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
aluster
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Scale List]
This is the location I have. The attached file adds the scales that I need. I found this somewhereon the forum a while ago so I don't know who to give the credit to.
Edit: Autodesk won't let me post the file so I have renamed the extension. Save the .doc to your computer and rename it to .reg then you should be able to run it.
gccdaemon
in reply to: aluster
This location was correct for 2012, but it's not working for 2013. I think they changed the override function. When i reset the scale list it puts the default scales in rather than adding the overridden values sent in your file. Hopefully someone from Autodesk chimes in on this, because I have standards i have to deploy.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
gccdaemon
Figgured it out!!!! On the very first scale, (the "0" grouping) you have to set the scale type to 3. If you don't it doesn't import the custom scale list. YAY ME!
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
