C3D2013
With QP activated, if I select an object (say an alignment or profile view) on the screen and want to pick its GRIP, I have to click the screen FIRST to get focus back to the drawing window (so two clicks). The same applies to the contextual Ribbon, it takes two clicks to 'press' a ribbon button if QP is activated.
C3D 2011 does not act like this.
Can anyone on 2013 confirm? Thanks.
I have had the need to double click Ribbon buttons and the model space display like this since 2010 or 11.
It's like you need an click to activate the ribbon or the model space display before being able to select a command button or an object on screen. I can't confirm it in 2013 but I can with 11 and 12. I do use QP's but have never noticed a link with this behaivor.
John Mayo
Just to clarify. When I started using 2013, I started noticing this behavior. Then after some testing, found it was only occurring when QP was activated. Then I went back to 2011 to test and it works fine (no double clicks needed) with QP disabled or enabled.
Both tested versions on the same machine. I'll do some more experimenting with settings and such, because the extra click is annoying to say the least.
I was about to post that I don't see this issue in 2013, but I was testing using a polyline (which at the moment does not have a context ribbon tab). I tried on an alignment, tin surface, profile view and section view, all of which have context ribbon tabs.
I just did a nit of testing, and if I select a plain autocad object, the program behaves as expected, i.e. the object is highlighted, the context ribbon shows and the cursor remains as a cross, ready to grip edit the object. If you select a civil 3d object, the object is highlighted, the context ribbon shows but the cursor changes to an arrow, which means you have to click back into the drawing area to get the focus back.
I just removed the context tab for tin surfaces from the cui andthen tried selecting a tin surface with the QP on and it still changed the cursor to a n arror requiring me to click back into the drawing to get the focus back, so it seems it is only related to the quick properties and not combined with context ribbon tabs.
This also occurs when you select multiple civil 3d objects, but does not occur if you include an autocad object amoungst the selection. Seems something about the Quick properties pallete is not being handled properly with civil 3d objects, as it is with autocad objects.
This is one that needs to be sent off to civil 3d support.
I tried with a surface and polyline in 2011, 2012 and 2013 all with Quick Properties on
When selecting the surface in 2011, the cursor remained as crosshairs and similarly with selecting the polyline
In 2012 and 2013, when selecting the surface the cursor remained as a "windows" arrow and I had to click on the screen to get focus but when selecting the polyline I got the crosshairs.
I'll raise a support ticket......done, will post back any replies
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks for the additional info. I didn't test with plain AutoCAD entities, but now I see it acts as you say.
I have opened a support ticket with Autodesk also.
Thanks.
Also happens if I select a Feature line (with QP on) and use LIST but behaves as expected if I LIST a polyline
John Mayo
Response received from Autodesk
"Many thanks for your support request and report.
I have done some digging and found this is a known issue with the Quick Properties in releases 2012 and 2013 as you correctly mentioned.
I will pass on your comments to the development team to add weight to the case. Currently they are targeting a fix for the 2014 release.
Sorry for the annoyance this may cause in the meantime.
Let me know if I can proceed with temporary filing of this support case or if you have any additional questions."
Targetting a fix for 2014 - unbelievable......what are we paying all this money for.....!!!!!!!!
I have yet to receive anything back from the support team.
Yea, I do not get this. It would probably take a single programmer a couple of hours to find this, fix it, and zip it up as a hotfix.
Perhaps we see where Autodesk's priorities are.....pushing ahead with the all singing all dancing "big picture" software that they think users want and forgetting about their bread and butter products that most users use day in day out.....
Was this issue ever resolved? Several of my coworkers are experiencing this issue but really like Quick Properties and don't want to shut it off. Did AutoDesk ever respond to the opened ticket or do we really have to wait for release 2014? Anyone have an update?
Thank you
Thank you
Not resolved.
It is still a bug in 2013 SP1.
@rkmcswain wrote:
@Anonymous wrote:Was this issue ever resolved? Several of my coworkers are experiencing this issue but really like Quick Properties and don't want to shut it off. Did AutoDesk ever respond to the opened ticket or do we really have to wait for release 2014? Anyone have an update?
Thank you
Not resolved.
....and probably still will be in 2014....
2015 SP3 and this problem still persists and drives me NUTS. Quick Propeties is simultenously the best and worst feature in AutoCAD.
I believe this specific problem is fixed in civil 2017, however a simular problem persists. When I pick a Civil object such as a label, then run EXPLODE, the focus is lost and a click is needed to continue. Also, if I have layers isolated and explode a label, it is removed from the drawing. The only way I can get it back is to UNDO until before I used LAYISO.
Can anyone replicate that? Thoughts?
Josh
