Valued Mentor
fcernst
Message 1 of 5 (289 Views)
2013 - General Segment Grade Text Component Not Updating
289 Views, 4 Replies
10-29-2012 03:12 PM
I extracted a dynamic feature line from the gutter flowline of my Corridor. I labeled Multiple Segments for the feature line with a grade and vertex style that uses the  "General Segment Grade" text component.
I am overiding lane cross slopes in the Section Editior and the segment grade labels for the extracted feature line do not update after I Update Corridor in the Section Editior.
If I raise/lower the CL profile of the corridor, the label updates. Just not reacting to these Corridor edits.
Peculiar behavior: The label will update to reflect the Corridor update if I Isolate it.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Hi Tim,
I've isolated this to the Update Corridor command within the Section Editor. The Update Corridor command is rebuilding the corridor, updating the surface, updating the Section View, etc., like it should, however the feature line labeling is not updating on this extracted dynamic feature line.
If I then select the Corridor and Rebuild it from the command on the Corridor tab, the labels update.
tcorey
Message 2 of 5 (276 Views)
Re: 2013 - General Segment Grade Text Component Not Updating
10-29-2012 04:40 PM in reply to: fcernst
Fred, just fyi, this works correctly in 2013.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Mentor
fcernst
Message 3 of 5 (274 Views)
10-29-2012 04:42 PM in reply to: tcorey
It's not working for me in 2013. It's behaving as I describe.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Valued Mentor
fcernst
Message 4 of 5 (252 Views)
10-30-2012 12:46 PM in reply to: tcorey
Hi Tim,
Fred Ernst, PE
C3D 2015
Ernst Engineering
tcorey
Message 5 of 5 (244 Views)
10-30-2012 02:22 PM in reply to: fcernst
Thanks for the follow-up. That's good to know. I'll file that in my (short-term?) memory.
Tim Corey, Owner
Redding, CA
