Civil 3D Forum
2013 Command line is off screen
4 REPLIES 4
corboto
6961 Views, 4 Replies
My command line is partially off the screen as shown in the attachments below.  Can someone help me fix this?  It started doing this after a reboot this morning.  I can't drag it, select it, or find a way to move it in any way.  I tried changing the resolution of my monitor thinking it might "bump" it back on the screen.  I'm probably missing something easy but I can't seem to make any difference.  Thanks.
Tags (2)
4 REPLIES 4
ToddRogers-WPM
in reply to: corboto
I have a blog written about this.  You can find it here...
http://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
corboto
in reply to: ToddRogers-WPM
That's it.  Thanks for the answer.   Hopefully this won't happen again.
Hi there,
I'm having the same problem, except your solution doesn't seem to work for me... 😞
I type in CUI which then appears at the topleft corner (the command line box so to speak) and then the screen pops up, I tell to dock at bottom, then it appears to be reloading something, but then it still doesn't show. And when I type something again in the commandline, really nothing appears 😞
Any thoughts?
EDIT: This is Civil 3D 2014 by the way, not 2013..
aalgarcia
This solution works!
AutoCAD Architecture 2013
Rail Community
