Has anyone encountered the following problem, when using a wipout within a block then used in a label stlye (note or cogo block) the tframe will not disappear and print when toggled off.
my test findings;
Started a new drawing from the 2013 Civil Metric Template that comes with the program,
created a polyline and truned it into a wipeout and said yes to delete the polyline, I then created a block with the wipeout within, the display acts just fine on its own or within the block definition, but when used in a label style or point block style the tframe will not disappear when toggled off.
Thank You
Trevor
I'm having the same problem, Trevor. I was upgraded to Civil 3D 2013 and all the pipe size blocks inside my drawing do not plot with the wipeout included; even when they show the wipeout working fine inside the drawing. I was wondering if anybody know how to fix this problem or if there is a technical Solution available. Please help.
