sboon
Message 1 of 15 (1,193 Views)
2013 bug - corridor feature lines
1193 Views, 14 Replies
04-17-2012 11:00 AM
I have a road corridor with feature lines connecting the road edges (cyan), ditchline (dark green), daylight_cut (yellow), daylight_fill (green) and daylight (white).  At certain random locations along this corridor I am getting feature lines which span from one station to another, ignoring all of the corridor sections in between.  The image below shows a daylight_fill line spanning over 60m, even though there is a daylight line through this region.
In this area a ditch line and a daylight_cut start at 4+110, skip over the next cut section at 4+120 and jump over a hundred meters to the next piece of ditch at 4+280
This corridor builds clean - no error messages reported.  Is anybody else seeing this behaviour?
Employee
dana.probert
Message 2 of 15 (1,179 Views)
Re: 2013 bug - corridor feature lines
04-17-2012 01:00 PM in reply to: sboon
Can you post the dwg? or a sample dwg?
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
sboon
Message 3 of 15 (1,170 Views)
04-17-2012 01:23 PM in reply to: dana.probert
Not on a public board Dana, but PM me and I'll arrange to get it to you somehow.
Employee
dana.probert
Message 4 of 15 (1,119 Views)
04-19-2012 11:17 AM in reply to: sboon
Can you make it fail in a tutorial or sample dwg?
You can email me the dwg if you like and I can see if I can get it looked at. First dot last at youknowwhere.com
Dana Probert, P.E.
Distinguished Contributor
bigblittlerent
Message 5 of 15 (1,106 Views)
04-19-2012 11:43 AM in reply to: sboon
In the Feature Lines tab of corridor properties...Does Branching Inward or Outward make a difference?
Brent
sboon
Message 6 of 15 (1,102 Views)
04-19-2012 11:55 AM in reply to: bigblittlerent
Nope.
Employee
dana.probert
Message 7 of 15 (1,099 Views)
04-19-2012 11:57 AM in reply to: sboon
I know that you have probably checked this... but just looking at your screen capture, I have to ask.
Is there a corridor surface in your dwg with the border only display on?
Dana Probert, P.E.
bigblittlerent
Message 8 of 15 (1,098 Views)
Steve,
To answer your previous question...Yes, I saw this a few times...branching outward solved it for me a couple times.
Good luck.
Brent
sboon
Message 9 of 15 (1,094 Views)
04-19-2012 12:08 PM in reply to: dana.probert
No surface Dana.  The green lines are Daylight_Fill feature lines, the yellow ones are Daylight_Cut, and the white ones are Daylight codes.  The darker green ones parallel to the Daylight_Cut  are the Ditch codes.
bigblittlerent
Message 10 of 15 (1,089 Views)
04-19-2012 12:16 PM in reply to: sboon
Steve,
Was the assembly built in 2013?...have had problems mixing subassemblies from different versions of software.
Brent
