AutoCAD Civil 3D General Discussion
Active Contributor
earlesinc
Message 1 of 5 (167 Views)
2012 vrs 2013
167 Views, 4 Replies
12-03-2013 06:29 AM
I have two questions. Hopefully someone can help.
1. I would like to down load the demo version of 2013. Will this override any of the current settings for 2012? (2012 is installed on hard drive)
2. Is there any site or way I can find a list of the things that have been fixed/modified or corrected that were not working correctly or just flat not working in vrs 2012 the were taken care of in vrs 2013?
Dave Z.
*Expert Elite*
troma
Message 2 of 5 (161 Views)
Re: 2012 vrs 2013
12-03-2013 06:41 AM in reply to: earlesinc
Doesn't answer your question, but you might find this list helpful:
http://cadpanacea.com/c3dbugs
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
earlesinc
Message 3 of 5 (123 Views)
Re: 2012 vrs 2013
12-03-2013 11:26 AM in reply to: troma
Thank you! That helps a little bit. From what I see most of the bugs are dealing with parts of the program we sldom use, but I cud be wrong. Anyone know about question 1?
*Expert Elite*
dgorsman
Message 4 of 5 (110 Views)
Re: 2012 vrs 2013
12-03-2013 02:54 PM in reply to: earlesinc
You should be able to install side-by-side without issue.  Mind the content browser, of course; can't remember if 360 is in 2013 or 2014.
Before you get started, make a system restore point.  If something unexpected happens, its a convenient way to roll your system back to a known-good point.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Contributor
DaveDrahn
Message 5 of 5 (88 Views)
Re: 2012 vrs 2013
12-04-2013 09:55 AM in reply to: dgorsman
Installing 2013 won't affect your 2012 installation in any way. Either can be removed without affecting the other as well.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
