Active Contributor
cjkiefer02
Message 1 of 8 (1,046 Views)
2012 Transportation Extension
1046 Views, 7 Replies
10-25-2011 07:26 AM
I am trying to install the 2012 Transportation Extension and when I go to use it I get an error that states
"Execute File is not exist: C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\C3DReportTE.dll, please reinstall program"
I have uninstalled 2012 Civil3D and reinstalled but still cannot get it to work.  It works just fin in 2011.
Colton
Product Support
AlmasSuljevic
Message 2 of 8 (1,033 Views)
Re: 2012 Transportation Extension
10-25-2011 08:24 AM in reply to: cjkiefer02
It seems that the file C3DReportTE.dll does not exist in the directory C:\ProgramData\Autodesk\C3D 2012\enu\Data\Reports\net\
See if you can make a copy of C3DReport.DLL (same directory) and rename that copy to C3DReportTE.dll and then restart Civil 3D. See if the message will go away.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Active Contributor
cjkiefer02
Message 3 of 8 (1,028 Views)
10-25-2011 08:37 AM in reply to: AlmasSuljevic
It dies work that way but the original report from  C3DReport.DLL is different than the report from C3DReportTE.DLL.
Active Contributor
cjkiefer02
Message 4 of 8 (1,025 Views)
10-25-2011 08:38 AM in reply to: cjkiefer02
Here is a screen shot of the 2011 TE box and the 2012 standard report box.
Product Support
AlmasSuljevic
Message 5 of 8 (1,015 Views)
10-25-2011 09:09 AM in reply to: cjkiefer02
I see the difference. My suggestion was in line that the C3DReportTE.dll was missing and renaming other DLL would allow it to run. Can you copy the 2011 version of the transporation extension C3DReportTE.dll to 2012 directory? That should work too.
Almas Suljevic
Active Contributor
cjkiefer02
Message 6 of 8 (1,011 Views)
10-25-2011 09:16 AM in reply to: AlmasSuljevic
I tried that also.  It is pulling from another file that I cannot seam to find.
Product Support
AlmasSuljevic
Message 7 of 8 (912 Views)
12-05-2011 01:02 PM in reply to: cjkiefer02
I reported this issue to the development and hope to see the new version posted in the near future.
Almas Suljevic
Active Contributor
Kevin.Spear
Message 8 of 8 (740 Views)
02-11-2013 08:46 AM in reply to: AlmasSuljevic
Any resolution to this?
Kevin
Kevin Spear, PE
Synergis Engineering Design Solutions
