The problem seems to be after I add new feature lines to an existing surface, some of the existing feature line/brake line loses there effect on the surface. But note they worked and had effect on the surface prior to the newly added feature lines/brake lines. Also note these added feature lines are in a total different area of the surface so should not affect the feature lines/brake lines. So what I needed to do was explode the feature lines that no longer had effect on the surface, and then use the command “create feature lines from object”, and then add the feature line back into the surface as brake line.
I'm using 64bit.
Please let me know if you have any questions etc.
Danny
Hey Danny,
Just curious, if you were to put the new feature lines in a different site than the originals, do the originals still stop working?
Tim
