Does anyone know if the Subassembly Reference (2012 version) is available for download?
All I seem to be able to find is the online html version. I need something that can be printed, the online html version is a PIA to work with.
Thank You,
Hi Brian,
Is this what you're looking for by chance?
Phillip,
Thanks for the response. Unfortunately the link you provided is not what I am looking for.
The documentation provided for older releases includes a PDF of the Subassembly Reference. I can't seem to find a PDF or other printable version of this document for the 2012 version.
The 2012 version is here (html): http://docs.autodesk.com/CIV3D/2012/ENU/filesCSH/GUID-B35ED378-3D86-4287-83B0-552DB29A0BF-0.htm
The 2011 version is here (PDF): http://images.autodesk.com/adsk/files/c3dstocksubassemblyhelp.pdf
I don't think the PDF version of the Subassembly Reference is available for 2012 and 2013 version. It is all HTML now.
Almas,
I was afraid that would be the answer. Is there some possible way to compile the contents of the html into a single file for printing?
Thank You.
You may want to see this post. At the bottom there is a procedure that one user provided to compile the HTMLs into one document converted to PDF. http://208.74.205.69/t5/AutoCAD-Civil-3D-Wishes/I-wish-we-had-PDF-s-back/td-p/3013556/page/2
Good luck!
