Civil 3D Forum
2012 Hotfixes not included in C3D SP1
10 REPLIES 10
Message 1 of 11
JeffPaulsen
1024 Views, 10 Replies
I found out that almost all of the hotfixes listed under C3D SP1 are not included in SP1. The only one that is included is the Prospector Lock-up Hotfix. Any others that apply to your C3D usage should be installed.
For our usage I installed the following:
  • AutoCAD Civil 3D 2012 Update 1
  • Autodesk Infrastructure Design Suite Network License Hotfix
  • AutoCAD 2012 Block Editor Save Corruption Hot Fix
  • AutoCAD and AutoCAD LT 2012 SP1 Ribbon Hotfix
  • Autodesk 2012 Content Explorer Service Hot Fix
I installed them in the order shown. I am not sure if the order matters but it seems to have worked.
Please note that the AutoCAD 2012 Performance Slowdown Hotfix (32/64 bit) is superseded by the AutoCAD and AutoCAD LT 2012 SP1 Ribbon Hotfix. So you only need to install the Ribbon hotfix. If for some reason you want to install both be sure to do the Ribbon hotfix last.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Tags (1)
10 REPLIES 10
Message 2 of 11
mathewkol
in reply to: JeffPaulsen
How did you figure this out?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 11
JeffPaulsen
in reply to: mathewkol
Autodesk subscription support.
Jeff Paulsen
Message 4 of 11
mathewkol
So the website says it does include them but the support techs say it doesn't? Interesting. What made you inquire or did they just tell you?
Matt Kolberg
Message 5 of 11
JeffPaulsen
Where does the website say it includes these hotfixes?
Jeff Paulsen
Message 6 of 11
Jeff_M
From the Readme for SP1:
You can apply this service pack to the following Autodesk products running on all supported operating systems and languages. Be sure to install the correct service pack for your software.
This service pack includes all previous hotfixes for AutoCAD Civil 3D 2012. The AutoCAD 2012 Performance Slowdown Hotfix is also included in this service pack.
So I was a bit baffled, too. The only one I could see not being included would be the Ribbon hotfix which came out after the Autocad SP1.
Message 7 of 11
JeffPaulsen
Oops, missed your second question.
I starting looking into this because we have two IDS licenses and multiple C3D licenses but only 2 people could get into C3D. I installed the IDS license hotfix (after SP1) and then all of our C3D licenses became available. I then contacted support to see what other hotfixes I needed to install. To be honest I didn't expect that I would have to install any based on past history. I thought I was reporting to support that the IDS license hotfix was missed in the service pack.
Jeff Paulsen
Message 8 of 11
JeffPaulsen
in reply to: Jeff_M
The way it was explained to me was that C3D SP1 included AutoCAD SP1 but no hotfixes.
The Ribbon hotfix has the same 2 dlls as the performance hotfix. They are newer versions however. I can verify, via version number, that the Ribbon hotfix and the Block Editor hotfix are not included.  The Ribbon hotfix fixed a lag issue I was having all day using feature lines.
From Support:
Hi Jeff,
It was very nice to speak with you today, and to follow up on our earlier conversation, ACAD C3D 2012 includes included ACAD 2012 SP1 and ACAD Map 3D 2012 SP1. I believe Hotfix - Prospector Lock-up is also included in SP1.  Many hotfixes listed under SP1 on C3D 2012 web page do not directly related to C3D 2012 (see below) thus they are not compiled in C3D 2012 SP1.
Welcome Screen Hotfix (UK English Only)
Welcome Screen and Ranges of Analysis Types Hotfix (German and Japanese only)
Autodesk Storm and Sanitary Analysis 2012 Hotfix (localized Civil 3D and Map 3D versions Only)
Standards Audit Report Hotfix for French AutoCAD® 2012
Autodesk Material Library Medium Resolution Image Library 2012
Autodesk IPv4 Network License Manager for Windows
Autodesk IPv6 Network License Manager for Windows
Jeff Paulsen
Message 9 of 11
Jeff_M
Interesting. The Block Editor fix should be removed from the list of "not installed with SP1", as the file date I now have installed is newer than the one in the HF zip file....suggesting to me it was installed by the SP1 install. Not sure about all the others....
Thanks for letting us all know your findings!
Message 10 of 11
JeffPaulsen
in reply to: Jeff_M
Jeff_M,
You're correct, the block editor hotfix should not be applied after the service pack. Thanks.
Time to undo the hotfix Smiley Mad
Jeff Paulsen
Message 11 of 11
I have applied this series of hotfixes after the SP1, and the Ribbon hotfix is actually causing the software to not restart on 1 in ever 2 PC in my organization that it is installed onto.
I have logged this with Autodesk via sub center help, case no: 068374480
Hopefully this can get resolved no..
Rail Community
