I'm the first to admit I could be dim at times, but where is the corridor section editor in 2012? Help says it should be in the modify panel... but I must be missing something obvious or my install is hosed.
Your Name
Your Name
Solved by Jeff_M. Go to Solution.
I looked ther first but only got view and vport options. no editor
Your Name
Your Name
Like I said - I can be dim at times Thanks Jeff
Your Name
Your Name
