Civil 3D Forum
2012 Alignment errors
7 REPLIES 7
Message 1 of 8
10315 Views, 7 Replies
Hi I was wondering if anyone else has been running into these in C3D 2012. They're exclamation points inside of triangles, I know it's supposed to be some kind of error in the alignment but if I open the same dwg/alignment in 2011 it doesn't have any errors... It looks like 2012 doesn't like to see two straight lines coming into eachother at a vertex without a curve even though it's still pretty much a straight line.  Does anyone know how to fix these or turn them off? I was messing around a little bit with them and snapping them onto eachother and I got some of them to go away but I was wondering if anyone knows more about these. There really isn't anything wrong the the alignment(s) either...
I attached a picture
7 REPLIES 7
Message 2 of 8
They are warning symbols and you can turn them off. Select alignment right click edit alignment styles display
Message 3 of 8
Message 4 of 8
Rather than turn them off, I would see exactly why they are reporting errors. Chances are that your alignment segments aren't tangent to each other. I would want to fix that.
My .02
Message 5 of 8
Is there a way to have it report on what it is finding wrong? I have this too - yesterday ity showed one exclamation point, today is is showing three for the same alignment.
Civil 3D 2012, Win 7
Message 6 of 8
mathewkol
Hover your cursor on that graphic and the tooltip will tell you.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 8
in reply to: mathewkol
thanks!
I found the Check for Tangency checkbox on the Design Criteria tab in ALignment Properties, too.
Message 8 of 8
What if the tooltip say "design violated: "? It didn't say anything about my error.
Nicks
Rail Community
