Hi I was wondering if anyone else has been running into these in C3D 2012. They're exclamation points inside of triangles, I know it's supposed to be some kind of error in the alignment but if I open the same dwg/alignment in 2011 it doesn't have any errors... It looks like 2012 doesn't like to see two straight lines coming into eachother at a vertex without a curve even though it's still pretty much a straight line. Does anyone know how to fix these or turn them off? I was messing around a little bit with them and snapping them onto eachother and I got some of them to go away but I was wondering if anyone knows more about these. There really isn't anything wrong the the alignment(s) either...
I attached a picture
They are warning symbols and you can turn them off. Select alignment right click edit alignment styles display
Is there a way to have it report on what it is finding wrong? I have this too - yesterday ity showed one exclamation point, today is is showing three for the same alignment.
Civil 3D 2012, Win 7
