Product Support
SethHall
Message 11 of 21 (434 Views)
Re: 2011 vs 2013 point cloud colors
11-16-2012 05:50 AM in reply to: BrianHailey
Hi Brian and Shawn-
I apologize as I should have been more clear. The issue stated in the first post is a spearate issue from the second one stated in post #6 of this thread. The PNG files provided by Shawn illustrate a surface difference that is caused by LEVELOFDETAIL, I confirmed this on my machine. The first post issue with the colors of the style, you are correct, that is a known issue that Development is looking into.
Again I apologize for the confusion.
Have a great weekend!!
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
sfore
Message 12 of 21 (427 Views)
11-16-2012 07:14 AM in reply to: SethHall
Seth, I just want to be clear.  Both issues still remain.  See pic in post 8.  I understand the 'level of detail' now, and contours did adjust, but that didn't fix the issue of surface creation from 'Ground' only Classification.  Brian's post clearly states this too.  The classifications are no longer recognized.
I look forward to a fix for both issues.
Thanks, Shawn
Product Support
SethHall
Message 13 of 21 (423 Views)
11-16-2012 07:25 AM in reply to: SethHall
Hi Shawn-
So this is what I tested:
In 2011 I took the LAS file you sent me, created the ISD, then created the surface from all the points in the ISD and did not specify ground only.
in 2013 I repeated the same exact steps and compared the results, they were exactly the same. I did this to rule out any possible surface creation issue as the description on post #6 eluded to.
So back to the original style issue, the fact that they are all the same color and the classifications seem to be incorrect compared to 2013 is causing the surface creation issue as a byproduct. Are you still getting an incorrect surface creation when you build the surface from all the points?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
sfore
Message 14 of 21 (419 Views)
11-16-2012 07:56 AM in reply to: SethHall
Seems to be confusion with this matter.  2011 is fine.  2013 in NOT.  See comparison below.
Turn off all point classification EXCEPT ground in 2011 and right click the surface and rebuild.  The contours are nice and clean.  Turn back on all lidar classifications, right click the surface and rebuild and you'll see abnormal contours from tree canopy, houses and such.  All point classification colors are being recognized just fine.
Turn off all point classification EXCEPT ground in 2013 and right click the surface and rebuild.  The contours are abnormal.  Turn back on all lidar classifications, right click the surface and rebuild and the contours are still abnormal.  Its the same either way.  The classifications in 2013 are not being recognized in color or surface creation when classifications are checked on or off. Thus, giving us a useless surface to do any type of surface analysis.
BrianHailey
Message 15 of 21 (416 Views)
11-16-2012 08:56 AM in reply to: SethHall
I suppose the current work around would be to create the surface in 2012 and then data reference it into your 2013 drawings, assuming of course you have access to the 2012 version of Civil 3D.
Brian Hailey
CAD-1.com
My Blog
ceethreedee.com
Message 16 of 21 (385 Views)
12-17-2012 07:14 PM in reply to: BrianHailey
Pretty terrible work around though.
Basically no point having point clouds in Civil 3D 2013 if you can't use the classifications to filter out ground points in las files.
Surprised this wasnt fixed as part of service pack 1!!
Regards
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
BrianHailey
Message 17 of 21 (366 Views)
12-18-2012 08:31 PM in reply to: ceethreedee.com
Regards
There are other point cloud files other then .las but I agree, if you are using classified .las files, they are pretty useless in Civil 3D 2013. Perhaps Autodesk has something up their sleeve. We can always hope.
Brian Hailey
CAD-1.com
My Blog
sfore
Message 18 of 21 (293 Views)
03-20-2013 04:30 PM in reply to: BrianHailey
Any word on if/when Autodesk is fixing the Point Cloud issue in 2013?  I just tried again with service pack 1 installed and issue remains.  Classifications aren't recognized and surface is still whacked with only 'Ground' Classification toggled.
The only thing I know to do at this time is generate my surface in 2011, export Surface landxml, then import it in 2013.
Hopefully Autodesk will provide some news.
Shawn
stevenh0616
Message 19 of 21 (234 Views)
06-24-2013 07:03 AM in reply to: BrianHailey
I"ve encountered the same issue. Does anyone know if this has been fixed yet? I'm running all the latest Service Packs to date and classification is not working thus leaving us no way to filter out just ground shots. I suspect that since this worked in 2011, I bet it worked in 2012 as well. I'm thinking it has to do with the big API changes in 2013 Civil3D as to why the classification is not working.
Steve
Steve
Windows 7 Enterprise 64-bit SP1
Intel Core i7 CPU X920 @ 1.73 GHz
16.00 GB RAM
Civil 3D 2013 - 2015
Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store
sfore
Message 20 of 21 (204 Views)
08-15-2013 08:49 AM in reply to: stevenh0616
This issue is finally fixed with Service Pack 2 for C3D 2013.  I just tested a lidar tile. The color classifications show and generating a surface from just ground classification produces nice contours.
