Anyone have any info on why I'd get this error when doing an Export to AutoCAD 2010/2007/2004...? It seems to be innocuous, and irrelevant, but it's disturbing none-the-less. I haven't been able to identify any reason why it appears, and all drawings seem to work normally, with no problems. AUDITs turn up no errors. So I've just been ignoring this message, but it's distracting. And it doesn't always appear... although I haven't been able yet to identify what causes it to appear in some drawings, and not others. I think it only ever happens when there's an XREF, but not sure... (Maybe when an XREF is in an older version of C3D/LDD/AutoCAD...?)
Don't know why this error occurs but I get it very regularly in 2012 - seems to occur after QSAVE (when it automatically does a save)
I have had similar messages in the past when XREFS are involved so I bound them first and all seemed ok, then didn't save the original dwg
neilyj (No connection with Autodesk other than using the products in the real world)
I can't obviously reply your trouble, but it sounds like a LAN or UAC problem.
Be sure that you have admin privileges on that computer, then unplug Ethernet cable and try again.
I've also concluded it is more annoying than a real problem. I see this often after creating a pipe network from a polyline, although I know it's happened after performing other tasks. To be on the safe side I will usually close the drawing and reopen right away.
We get this this message regularly in 2012. Most people ignore it but I always close the drawing and run a recover. Half the time it finds an error or two other times it finds no errors.
A regular occurance in 2012 for me too. Again rarely appears to relate to anything specific.
Yes. Every time I try to export a C3D drawing to another format, like 2004 DXF as an example, since that is what I'm doing at the moment. (C3D 2013)
We get the same error, but only when a specific dvb project file is loaded. We can open the drawing and qsave with no message, once we load the dvb, then the message shows up. We haven't isolated the exact cause, yet.
The error occurs when copying a surface from a xref and pasting in current drawing. Therefore, it not a generic vba/dvb issue.
We get this messages offten. I Noticed that it happens after adding tag labels to a table. If I do a recovery, it finds errors and removes the tags. Once I added them again the error returns.
-Miguel
I get this every time I do a "copy clip" or "copy with base point". Recover says, "no errors" etc. Audit, same... We are running 2015 w/ Trimble running on top of it.
